321 - 340 of 1,376 Posts
Do some searching, you'll find the Forester has a 5x100 bolt pattern. Only way to fit a 5.114 is to swap STi parts (axles, hubs, etc). Much cheaper to find a different wheel.
Here, read this thread (sticky at the top of this forum) which is more about wheels than tires...though it is OEM specific it provides some info:
http://www.subaruforester.org/vbulletin/f72/subaru-oem-wheels-fit-forester-19106/
Been searching high and low for 16" winter rims. The only ones I can find have 42 mm offset. I know the recommended offset is 48mm but 6mm is less than 1/4 ". I find it hard to believe this little difference will cause premature wheel bearing failure, handling or any other problems related to offset. Any opinions on this?
Opinions I have a few. :icon_biggrin:
If you are running a wider than stock wheel 42 mm is acceptable. 6.5" wheels with 42 mm will put additional stress on the bearing and may contribute to premature failure. Yours may be fine, but just know the risk going into it. Keep in mind Foresters and Outback have 48 mm offset and the Imprezas have 53/55 mm offset. So we are already pushing it a little with our 48 mm considering they are basically the same platforms.
I installed a set of Tarmac 2s (17 X 7.5, ET48) today in Steel Grey. Tires are Advan S4s in P235/50-17. With the ET48 wheel, no spacers were required to clear the rear struts.
Based on research here and my experience with this wheel/tire combo, with an ET48 wheel you can fit a tire with a cross section of up to 9.5 inches. Once the cross section reaches 9.7 inches, spacers will probably be needed.
Bear in mind that for every 1/2 inch in wheel width deviation from the "measured wheel size" used to establish the cross sectional dimension of the tire, the tire's cross section will change .2 inches. So for example, if the listed cross section of the tire is 9.5 inches on a 7.5 inch wheel (like my Tarmac/Advan combo), going to an 8 inch wheel will increase the cross section to 9.7 inches.
I hope this observation is useful!
Photos below of the new wheel/tire combo. My FXT rides on Swift springs and stock struts.
Oh man...what a day yesterday. What did I learn? 235/50-17 Falken 912's do NOT fit on 04 STi BBS wheels with 3mm spacers, OEM suspension. Close, very close though. I guess I misunderstood the spreadsheet:
Dahu posted:
Falken Ziex 912, 235/50-17, STi 17 x 7.5, 53 offset, Rubbing: Y -rear strut tower, Spacers: Yr-3mm, OEMsuspension
I thought this meant they WOULD fit with 3mm spacers in the rear...but no go.
Then I read Tussen's post:
Michelin Pilot Sport A/S, 235/50-17, STi 17 x 7.5, 53 offset, Rubbing: Yes-rear (bad), Spacers: 3mm-rear, OEM Struts/Forester Swift Springs 3mm=no rub
This confused me even more. Tire rack lists the section width (on a 7.5" rim) for the Pilot Sport A/S as 9.7". Falken's website lists the section width for the 912 (on a 7.5" rim) at 9.4". So if Tussen fits with the Pilot Sport, why can't I fit the 912's with 3mm spacers???
Also, next week the Swift Springs and GR-2 Struts go on, anyone know how this will affect the final fitment, working for or against me?
-Tire brand and size: Michelin Pilot A/S 235/50/17
-Rim width and height: 04 STi BBS 17" x 7.5"
-Rim offset: +53mm
-Any rubbing: Unacceptable rubbing in rear
-Suspension: Forester specific swifts. Negative camber, -1 in front -0.75 in rear.
-Using any spacers? 3mm in rear = no rubbing
Using any spacers? 3mm in rear = no rubbing...
i'm dumfounded :-( Tussen is a magician :)
anyone know the stock alignment specs for the rear, is there additional alignment beside the strut tower?
Going to order Prodrive GT1 in a few months, and wondering about tire sizes!
The wheel is an 18x7.5, with a +53 offset...i was going to get a 235 40 18 tire.
Based on the previous numbers, do any of you see a problem with my tire size and offset (i know offset for an 07 forester xt is +48)
Let me know please
I'm sure this has been answered somewhere in here... but I'm too lazy to dig :biggrin:
I just got 16x7.5 winter rims for the foz, what's the tallest tire that will fit on them without rubbing?
This one is my favorite. :wink:
Rubbing - Please help
Vehicle: '06 XT
Tire brand and size: Toyo Proxes 4 235/50/17
Tire brand and size: Goodyear Eagle GT 225/50/17
Rim width and height: Rota G-Force 17 x 7.5
Rim offset: +48
Any rubbing: Yes
Suspension: '07 WRX struts / Wagon Pink Springs / STI rear sway bar
Using any spacers: no
Both sets of tires rub (where the tread meets the sidewall) on the inner lip of the rear fenders. I am driving it but it rubs hard on medium bumps and turns so I don't push it too hard through the corners.
I'm thinking about going to a +53 offset to try to solve the problem. Anybody know if this will take care of it and not create rubbing somewhere else?
I was also thinnkig about using 1/4" saggy butt spacers but I don't know if that would be enough. Any suggestions?
Thanks.
Vehicle: '06 XT
Rim offset: +48
Any rubbing: Yes
Thanks.
If you go with a +53 offset wheel, you will have rubbing on the rear struts. (with stock suspension) I'm not sure how much difference there will be with wrx suspension parts though...but I can't imagine much.
Vehicle: '00 S
Tire brand and size: Yokohama YK520 215 55R16
Rim width and height: Konig Incident 16 X 7
Rim offset: +40
Any rubbing: No
Suspension: Stock
Using any spacers: No
I'm not a member of any Legacy forum so I'll ask here:
I am wondering if 205/70R15 will fit my '95 Legacy LS because this way I can use the same tire as my foz. Any insight would be appreciated! TIA,
Tyler.
Tyler.
Maybe, its going ot depend on the offset of the wheel you use . I have a set of 205/55/16's on WRX wheels mounted on my wife's '97 Legacy. However when I tried to fit 215/60/16's from the Forester on there they hit the rear strut and wouldn't even sit flat against the hub.
I'm not sure of the offset, but they are the stock sport alloy 15" rims.
