I've had a check engine light for like a month now that will go awake and come back. It's for a very small evap leak. I decided to take a look at the filler neck, cause everybody says they rust out bad. This is the only part of myn that was rusted, everything else was fine. This is right where it you put the gas nozzle in.
Is this where it usually rusts out? Should I replace it to get rid of the CEL? If I decide to buy the replacement parts, Do I only need the filler neck or are there other components?
Thanks guys!
untitled-1.jpg by Connor Lugenbeel, on Flickr
untitled-2.jpg by Connor Lugenbeel, on Flickr
Thanks guys!
